92sho16
b00sted
When im driving along an have the need to downshift sometimes when im going down in rpms a backfire sort of sound is emitted from the exhaust. Does anyone know what causes this?
Um, that doesn't mean anything. I've seen SHO's running on anywhere from 3 to 5 cylinders that still seemed to be plenty powerful. Check the routing. It will take 2 minutes or less. If the plugs are indeed routed correctly, then your next step is going to be to remove the upper timing belt cover, and verify the timing between the cams and the crank.92sho16 said:Wires are routed right because the car isnt down on power.
Mr. Anonymous said:Um, that doesn't mean anything. I've seen SHO's running on anywhere from 3 to 5 cylinders that still seemed to be plenty powerful. Check the routing. It will take 2 minutes or less. If the plugs are indeed routed correctly, then your next step is going to be to remove the upper timing belt cover, and verify the timing between the cams and the crank.
