93_SHO_FL
Ok, so I just bought a barely used EZ-Scan 3000 OBD1 unit from a forum member here.
He said it works fine. So I plugged it in, followed the instruction manual, and it won't scan.
Here's what I have...
93 ATX with 94/95 EEC-IV unit (might be part of my issue)
When I run either the KOEO or KOER, both talk to the EEC.
KOEO, fan cycles, fuel pump cycles, CEL flashes in sets of 3 flashes in 3 cycles, then the unit kicks back and displays "Vehicle is not responding"
KOER, idle revs up, holds for a few, flashes CEL 3 times, then says same thing, then idle dips under 500 rpm, then levels back out at 750-800rpm with same Vehicle is not responding message.
I tried these configs on the unit:
93 - P
94 - R
95 - S
93 - R
93 - S
94 - P
94 - S
95 - P
95 - R
All have same results. The only thing it will do successfully, is clear codes.
I have ordered a new USB to PC cable to upgrade to latest firmware. Hoping this will fix it. However, I cannot helpbut think there is a special combo of year and 8th VIN letter because of the car being a 93 and the EEC being 94/95 unit.
I'm open to ideas. I'm trying to fix an annoying CEL and a sporadic misfire when warm.
I have not tried on another OBD1 car yet, but plan to in a few minutes on my friend's 93 TBird SC. If it works fine on that, it has to be the non-matching EEC.
93 - P
94 - R
95 - S
93 - R
93 - S
94 - P
94 - S
95 - P
95 - R
