automatic transmission question
shocar
shocrazy
Bend
I have a atx tranny out of the car. Torque converter has not been removed. My question is. There is a little bit of fluid that has leaked out from behind the torque converter while it's been sitting there for a couple of weeks. I am installing it in a car this weekend. Is this normal for it to weep a bit because it's not connected to the motor or is there a seal behind the torque converter that needs to be replaced
Mr Anonymous
Tire Wall
Nope. It likely means the torque converter is not fully engaged on the pump shaft and stator support. A little wiggling and pushing should make it clunk into place, but for a used tranny, I'd pull the converter, replace the $7 seal, and make sure the snout of the converter doesn't have a groove worn into it from the seal.
