autolamp
only1me
Missouri
I have already done a search but it didnt answer the question I have. My autolamp quit working on my 91 and I cant find for the life of me, where the relay is located for the autolamp.
aggiesho
Houston, Texas
i took my autolamp swich out and opened it up and the small circuit board was covered in grease and i just wiped it off w/ my shirt, put it back together and put it back in the car and it works again.
firstgen89sho
former Slo_SHO
Lloydminster Sk, Canada
the autolamp relay is to the left of the glovebox opening on the metal support rail inbehind.
another way too look at it is to remove the radio, and it will be in behind to the right on the support beam.
only1me
Missouri
Thankyou so much, I went to the yard today saw a few cars with autolamp option but was clueless as to where the relay was, but now I know thankyou.
only1me
Missouri
you were right thanks it was the switch I took it out cleaned it and its working perfect now thankyou.
red89mtx
Guest
kenosha area wi
did the same thing just now mine only worked on max before cleaned the grease all fixed guess ford over did it lol
only1me
Missouri
It just operates the lights if you choose not to use the headlight switch when it gets dark you can slide the **** up to a certain point and the lights will come on, and you can sit it also so when you shut ur car off ur headlights stay on just a bit to see where ur walking and they will shut off automaticaly.
