Audio Connectors
Jim Merriman
Southington, CT
Hi guys: Would any one know what the mfr and part number of the audio 14 pin connector that is used on the Gen 1 JBL system for the 4 primary channels that goes out of the amp to the speakers. I believe there are 11 wires on female sockets in this connector. Eight wires go to speakers and 3 wires go to the other woofer amp. That leaves 3 open positions in the connector with no pins installed. There isn't a mfr reference or part number stamped on this connector. I have pictures of this connctor in case there are any questions. I want to mate this connector to its mating connector with male pins in it. and then run it into the amp I am going to use in the 91 Plus.
Any help would be appreciated. Jim
Jim Merriman
Southington, CT
Paul:
This link was pretty helpful. I found the part numbe rof the exsisting audio amp connector, which is WPT296. I didn't see a mate listed for it. Now I'll call my Ford parts buddy and see if he can ID it. If it doesn't exsist in a raw connector form, which it may not, I guess I might go to a bone yard and see if I can fine a Taurus with a JBL system and rip apart the amp to get the mate out of that, but it fear that I'll be a PCB right angle connector and won't be as great a connection. Maybe I'll just have to get some Molex connectors and make my own wiring harness up!
But thanks for the help, as usual, you know all the stuff!
Regards
Jim Merriman
SHOZ123 said:
