ATX owners..question about RPMs...
TwiceSHOwn
Atlanta, Ga
Do your Auto's have different RPMs at the same speed according to the weather? I was just curious cause on cruise at 70 (on the same road i take to work everyday) soemtimes my car is right above 2500 and sometimes right below. I think it has been as high as 2750 and as low as 2300 or so at the same 70 MPH cruise control. I think that i can attribute it to colder weather my car actually revs a little higher or maybe its that the car is warmer...
Tell me what you guys think about it.
Brian
93 Silver ATX 57K
LPM
80MM MAF
Y Pipe
Eibach + Tokikos
Front and Rear STBs
Cold air snorkel
TCE SHO stopper brakes
Recovering from its 60K...sigh
shotx
Premont, TX
Mine does the same thing.
-Roy
  • 95 Silver ATX
  • K&N filter
  • 80mm MAF (to be installed)
  • LPM chip
  • Summit turbo mufflers
http://www.photoisland.com/servlet/GuestLogin?USERNAME=shotx
password: 95sho
89 MTX <SOLD>
Red94
Yaphank,Long Island
Mine also does this.I believe that the torque converter does not engage until the car reaches normal tempature.Even then the car needs to be restarted.Thats the way it works on mine at least.
TwiceSHOwn
Atlanta, Ga
So once the car is warm AND restarted only then does the torque converter start "locking" up? Hmmm... Keep the experience coming, i'm glad mine isnt the only one doing this...
93 Silver ATX 57K
LPM
80MM MAF
Y Pipe
Eibach + Tokikos
Front and Rear STBs
Cold air snorkel
SHOtime93
Michigan
yep put me down, mine does the same thing...I never thought much of it.
1993 White SHO ATX
Stock under the hood so far...
GTS Headlight covers
Saddleman Hood Bra
GTS Sunroof ventvisor
Tinted Windows
"SHO" windshield decal
"SHO" filler decals
400watt PPI amp and a single Fosgate HX2 12"
Powered by YAMAHA
M
Mikeys_Taurus
Guest
Is this a SHO thing? I'll lock up regardless of engine temperature.
poissonverte
iowa city, ia
No it will not lock up until your engine gets to a certain temperature then you will see the RPM's drop to normal rate when it does.. I never have to restart the car it will do it automatically after a while on the highway.. Doesnt take that long actually..
TwiceSHOwn
Atlanta, Ga
"Not that long"
On my car i drive for like 10-15 minutes max...? Is that long enough?
93 Silver ATX 57K
LPM
80MM MAF
Y Pipe
Eibach + Tokikos
Front and Rear STBs
Cold air snorkel
S
slosho
Guest
At WOT my car shifts early, i.e.: 1-2 redline, 2-3 6000rpm, 3-4 6000rpm? What da dealyo??
95' ATX Opal Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a "PCV" line
Fog light mod
Reverse light mod
Sony head unit (el cheapo cdx-650)
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
TedB
Decatur, AL - New Orleans
Torque control is set to engage when the coolant temp reaches 180 degrees. This can be easily changed, but I don't know how advantageous it would be.
T
Tommy the Greek
Guest
TwiceSHOwn, mine does the same thing. My job is only 3.5 miles away form my home but still need to take the highway to get there and it does not shift into overdrive until it reaches the appropiate temp. which I don't know what it is
When I use to work 35 miles away from my house (1 way) the car shifted into overdrive after being on the highway for 15-18 min doing 55mph. It also depend on the temp. too, if it is 40 degrees out it will shift faster into overdrive. If it is 10 degrees out, it won't shift into overdrive for a long time
'95 SHO ATX, 55W foglights, coneless, fishtank mod, white/mocha cloth interior, 45K, Mobil 1 10W-30, build date 12/13/94.
Below is a pic of her @ 28K miles (Nov. 6, 2000)off interstate 87, overlooking Lake George, NY.
www.roushind.com
TwiceSHOwn
Atlanta, Ga
Ted if you had a bad thermostat does that mean your tranny would never go into lock up mode?
93 Silver ATX 57K
LPM
80MM MAF
Y Pipe
Eibach + Tokikos
Front and Rear STBs
Cold air snorkel
SHO 3.0
Welland, Ontario, Canada
I had a truck that had a bad O2 sensor, and wouldn't go into overdrive until I replaced it. Then after it warmed up, 5-15 minutes, it locked up. The O2 sensor is basicly a tempeture sensor, so I don't know if the SHO reads it from them or the coolant temp sensors.
TedB
Probably not.
The computer reads temperature from the ECT only. If the thermostat is faulty or this sensor is faulty, there will be problems.
FYI: The small sensor at the thermostat housing is for the temp gauge only, and is not the ECT sensor.
