ATX Oil Pressure Sender Install
seraphiem
Jersey Shore
Can't figure out how to remove the single wire lead from this oil pressure sender.
Do I need to pull this right angle boot and remove a nut?
Or is the right angle boot the actual part of the lead and just spin it off?
If so, do I have unclip one of the connections there?
I have an ATX so I have to it all from the top. I bought the sender socket to make my life easier yet since I have to remove the lead first this is becoming increasingly painful.
Thanks All
RAYJAY
WHO ME ?
UNION DALE PA
did mine from the top also the wire just pull's off the sender .i just laided on the snakes
and reached down behind the motor .hope you have small hands ........
Jeff
Yamaha V6
SHO Enthusiast
Rhode Island
The "L" shaped end on the wire IS the end of the wire, it's press-fit on there, wiggling back & forth will help, but be careful not to break the "L" off. Essentially, it just pulls straight off.
Ishodu
Pic shows the stock sender, I know I had to install a extension for that setup but its almost the same, just pull the "L" off the post on the sender.
seraphiem
Jersey Shore
Thanks for the help.
I finally got it pulled off and completed the replacement. Looks like no more oil leaks! :biggrin:
Also,
Any idea what all the connecters are for right at that sender? I was tugging on them pretty good and I just had a totally unrelated yet bizarre no start
condition. Solved that issue (a bad ground from previous work today) yet am curious on what I could have messed up.
Thanks Again All.
