Atx issue
J.L.Gordon
Carlsbad,CA
95atx.Just replaced the oil sending unit disconnected the battery unplugged everything in my way,sprayed the area with simple green soaked for 20min and hosed it off.Now my trans shifts in and out of gears when it wants sometimes slamming into 1st as I'm coming to a stop.I did not have any of these issues before this happened.
hawkeye18
Sorta cares
Norfolk, VA
Sounds like either you got the connector to the VSS wet, or you forgot to reconnect it. Double check all your connectors and make sure you didn't leave any behind.
