gurucomputers
My 94 SHO Trans is really acting funny. Yesturday it was fine now today ??? I went on a quick 20 drive to Wally World and on the city street I noticed that it would slam into gear going from 1 to 2 and when slowing down it would slam into gear going from 2 to 1. Hard enough to make the tires chirp. I checked the fluid and was fine "Good color, full, and no burnt smell". I decided to drive it some more, at wide open throttle it seems to be happy. It shifts firm at 7000 through all gears including OD. The problem is when you are driving on a 35MPH street where you don't throttle it up much just normal criusing. I then went out and manually shifted it through 1-2-D and moved the shifter up at about 4000 under normal cruising throttle. When it shifted up there was no hunt for the next gear nor did it seem to slip any by watching the tach. I did both the KOEO and KOER test. What I got which has been an ongoing issue is the 176 "HEGO lean", 332 "EGR Not detected" and 543 "FP Circuit failure" codes. I don't beleave this has anything to do with it cause I have been troubleshooting these codes for a while and that another issue anyway. Gears 2-3 and 3-4 seem just fine. Any body have a direction to go in
