ATX Coolant Hose Diagrams
SHO Continental
Moderator
Northridge, Cali
This is on my '93 ATX.
I have a leaking hose low on the engine (driver's side/rear) I can't really see in there much. Was wondering if anyone has a diagram of the Coolant system, or pictures of this part of the engine out of the car or in the car?
yzstud
< my kawi
Minnesnowta
resized for ur liking
probably item #6 that is leaking, i have had every car leak at that hose
SHO Continental
Moderator
Northridge, Cali
It's #6.
Looking through the pictures from my motor swap (less than 200 miles ago) I only found one from the driver's side that showed part of the hose, and it's blurry! Guess I should have put a new one on, or at least swapped my known good one from the original motor.
Anyone have a picture of the hose? IIRC it has a rubber portion that is crimped onto the metal hard line, is that correct? Just want to make sure I get the correct item to put in it.
yzstud
< my kawi
Minnesnowta
yeah that metal portion is a compressed clamp on the tube side, just cut off the metal clamp and replace it with some good hose clamps
also, just buy like 1ft of 3/4 heater hose
