BrentB
On a hard launch it won’t shift into second. Checked fluid And filled it to max hot line. Didn’t help. I’m guessing they will have to lower my shift points. Issue with 2013?
They will, it’s night and day. I’d knock myself into limp mode on launches all the time before the trans mounts.Mine is perfect in the street Abd only acts up at the track. When traction is awesome. So I emailed GH I’m sure they will fix it. I’m also going to go with Anthony’s trans mounts. Should help in case it is a movement issue.
Mine is perfect in the street and only acts up at the track. When traction is awesome. So I emailed GH I’m sure they will fix it. I’m also going to go with Anthony’s trans mounts. Should help in case it is a movement issue.
I have not gotten wheel hop. I’m just thinking it’s torquing over to much. Refuses to shift at the track I’m just unlucky I guessI must be doing something wrong. I never felt an inkling of wheel hop or triggered a limp mode. Just the “Service Advancetrac” warning after every run.
I’ve always ran in Drive as well.Prepped surfaces always cause TC problems for many manufacturers.
You need to get a revision from your tuner.
My car never has this problem and runs faster times in drive
I’ve tried both at the track. Same issue with shifting though.I’ve always ran in Drive as well.
