arh! codes please help
sho'd
Git R' Done
ontario,canada
can anyone tell me what these mean
514-IAS fail
214-CID circiut faliure
and what should i look for? these are new codes that i have not gotten until i did my damn intake. thanks for any help
i also got these one from my abs 23-LH Front Outlet Valve what is that??
Rockledge
Pluggin' away
Connecticut
The 214 code implicates the CID sensor (a/k/a camshaft position sensor) or the CID circuit.
There is no 514 code, you might want to double check that one.
sho'd
Git R' Done
ontario,canada
ow, shoot i mean code 551 IAS Failure, i did a search on the CID and found out about CID, but there dosn't seem to be any symtoms? my tach works, the only thing i find is that the car sometimes takes a few cranks to start. i'm lost.
sho'd
Git R' Done
ontario,canada
i figured out what the IAS is, it's the solinoid that controls the secondaries, was unpluged. now i just have to figure out what the **** is going on with my cam pos sensor. anyway to test the cam sensor? i've been searching thats how i have found some of the info on the other. still searching.
naval-avi8or
Chesapeake, VA
You need to replace the CAM Pos sensor. The symptoms you are having are a bed CAM sensor. The reason why it takes several cranks is the computer is trying to determine which cylinder is number one due to a lack of cam pos input. Each time you crank it the PCM picks a diferent cylinder. until it fires.
The TACH gets its input from the CRANK CENSOR output (and its not directly from the Crank pos sensor) not the Cam pos Sensor.
sho'd
Git R' Done
ontario,canada
thanks bud, i guess i will be ordering one monday. man this car is going to make me broke. can i take the cam sensor off without haveing to remove intake and all?
naval-avi8or
Chesapeake, VA
Yes, just be very carefull with the two retaining screws. They are very soft metal and are easy to strip the heads out.
