Here's my day yesterday. Found my receipt for the Advanced Auto battery I purchased in December 2003. Yeah.
Drove the SHO to work, no rpoblems. Mind you its hot but I'm afraid to use the AC and no radio. Head out to lunch using the SHO. On the way back from lunch, I'm sitting at a stop light and the car just shuts down for no apparent reason. No hesitation, strange noices, just shuts down. I turn the ignition off and the car starts right back up no problems. Get to work ok after that. Leaving work and power locks aren't working. Try to start the car and no start. No power. Jump start the car with the portable jumper starter and car is running fine. Head to the Advance Auto that is close to work different from the one I visited previously near my home. It was about a 15 minute drive with no problems after the jump start. Get there and the guy tests my battery. Machine reports a good battery. I start the car and it starts right up. This is getting fustrating. Leave Advanced Auto and head home. Gas was getting low and right when the gas low light comes on the car hesitates like it wants to stall. Pull into the gas station to get some gas. Car starts right up and I head to my dads place for a visit. Leave there for home and once again car starts right up. I'm at a lost.
Replaced the Battery Saver red fuse this morning with one of the spares. Did you do anything with the ********* fuse/relay that is also marked as battery saver? Checked my ground from the battery and the connection seems ok. Undid the bolt and rebolted everything just in case. Decided not to drive the SHO today. May drive it a bit tomorrow before scheduling an appointment with the dealer later next week.
