Anything else I should do?
Well they took the '97 off to the repair place today on the hook. I believe the TC is FUBARED and maybe the tranny. I am getting a heavy duty TC put in it, an new tranny from FPS if needed, a new Electric Pressure Control Solenoid and I am putting in 3.98 gears. Also sent the FordChip off to get flashed for the gear ratio change.
Anything else I should do while the tranny is out?
Mike Kopstain
Arlington Heights, IL
Well on hot rods we double stack the clutches. You could possibly doublestack the clutch packs on the AX4N. Also, I believe there is an updated bushing to prevent torque converter failure.
bmytych
