Anyone have anymore info? I talked to 2 dealers and neither one knew anything about PTU smell issue. I even gave them the ssm number and they didn't find/have any info on it.
I'll give it a try. I gave the service manager the number and told him its a common issue and numerous information about it online and he said that he can find anything online if he looks hard enough and that if he looked hard enough he could even find where it says he's a millionaire. Tool...
I was trying to present him with the number after car was looked at to try and gather more info about it and that's when he immediately went into the internet deal. His customer service was terrible. I was the only customer there and it was hours before closing. The car always smells when I bring it there but with no leak, they won't fix.
What's your drivetrain/powertrain warranty look like? Does CPO warranty travel or is it dealer specific?I was trying to present him with the number after car was looked at to try and gather more info about it and that's when he immediately went into the internet deal. His customer service was terrible. I was the only customer there and it was hours before closing. The car always smells when I bring it there but with no leak, they won't fix.
My PTU grenaded at 50k mi while cruising on the highway @ 65mph. Was covered under warranty at that time. Otherwise would have cost $1,300.
Get under the car asap. If its propane most likely its PTU. Trust me i know just replaced mine. If your lucky the vent popped off. Easy fix, but means you definitely need new fluid. If your not lucky your PTU is letting go. Fluid change will give you a definitive answer, do it as soon as you can.Not sure if I should start a new post or revive this one so here goes.
2014 MKS 72,000 miles 3.5 EcoBoost AWD
I have the propane smell in the interior of the vehicle I thought it might be exhaust took to a mechanic. No exhaust issues found checked the driveway and near the rear of the car now see signs of fluid leaking. Oh, and I bought the car 2 weeks ago and can't easily afford a 2k fix right now. I attached a picture of the leak. Is this the dreaded PTU?
How does it get fixed and where do I take it?
Dealer? (I have an appointment in two days)
Or would most mechanics be able to handle this?
Since I have to drive it home from work and then back to the dealer is there a way to baby this? slow speeds? Avoid stop and go?
Thanks for your help I've got my fingers crossed.
Or maintain every 10K for severe conditions/30k for normal conditions. 10K in one particular police fleet in the salt belt has worked to eliminate failure. Need insurance? Step up to higher quality fluid.
