Anyone running 47lb SHOSHOP injectors?
Toolman
Boost it!
Grand Lake, Oklahoma, USA
I have these in the turbo and was needing some base injector slopes and offsets. Anyone have any experience with them? I know I should get the 48lbers, but I have sunk enough dough in this project already. So I need to get them to run for me.
jeanrw2000
Lechon Asado!
Brawley, CA
i am but as you know my car is down due the idle problem i havent have the opportunity to really enjoy then yet
twr
whoohoo
half-way there, I think.
Tim,
When I was running them I had the high slope around 45 and the low slope maxed out at 112. I haven't messed with the offset or break points yet. But the car ran fine. I've actually had more problems with the tuning the 48lbs.
Toolman
Boost it!
So your offset and breakpoints were left stock (the XJ2 setting?)..
Did you happen to use the 90mm MAF? I am just wondering if it is correct
twr
whoohoo
No, I started with the Lincoln 80mm MAF and then went to the 80mm Lightining MAF. Yes I left the offset and break points in the stock settings. Unfortunately I have not devoted a lot of time to tuning, mainly because the car has a hic-up at idle and I have not had much free time as of late.
