anyone know where to find an oil pump????
bulldogs3d
new york
looking for an oil pump for 93 3.2 atx can't find one ford has discontinued them I think this might be the problem all of a sudden my valves started making noise people tell me if the valves actully went they would go gradually these made noise right away and I was only down 1 quart of oil I bought an oil pressure gauge and will check my pressure today. if I still have pressure my pump is okay so would anyone have any other suggestions or have you ran into this before would appreciate any imput thanks.
SHOtimer
#2910
Santa Clarita, Ca
The chances that you need an oil pump are very slim. They are hard to come by, but they do not go out very often at all. You need to make sure that you are running full of oil. The valve train in the SHO will always be a bit loud, that doesn't mean their is a problem.
Doug
bulldogs3d
new york
I filled it with oil I was only a quart down but it did do anything It's more than just a little noise you can tell there is something wrong but it really sounds like it's coming from the top half of the motor no big knocks as if it were a rod
bulldogs3d
new york
never I don't even know what that is do you think this would be something I can fix I drove it right home and left it only about a mile if it's not oil pump it would really suck needed a new motor
Rockledge
Pluggin' away
Connecticut
Timing chain rattle?
If your pump was near death and causing enough flow concerns to create top end noises then I'd think the oil light would come on now and then.
autobahnsho
SHO Victim
NY for now, WY for real
Valve lashing is checking the height that the valves are allowed to travel- Imagine a "T" where the top part is the part that touches the cylinder, and the vertical part is connected to the Cams. (Sort of.)
You can add or remove "shims" which are like discs you put on the vertical part of the "T" to change the height..
I agree, you would see the red or yellow "oil" lights come on if it was an oil issue.
You can pop the oil filler cap off (engine off unless you want to see oil come out!) right after shutting the car off and see if there is oil on the stuff that you see there. That is the "top" of the engine, it's actually a camshaft and the (effectively the bottom side of the "T") assembly that connects to the valves.
HopefulSHO
Bellevue, NE
Pretty rare an oil pump fails on the SHO. I'd bet more on an ejected shim or failed chain/chain tensioner; if it is coming from the top end. Really hard to diagnose over the internet, though.
SHOtimer
#2910
Santa Clarita, Ca
I have had my oil cap off repeatedly with the motor at idle, and even with slight blips of the throttle oil does not come out.
You can have the motor running and unscrew the cap to inspect what if any noise changes you can hear, and to observe oil flow.
Doug
