Anyone heard of GM Syncromesh Transmission Fluid?
Mike Spataro
E.Meadow, NY
I recently read some good reviews on MTX transmission fluid sold by General Motors for FWD vehicles with manual transmissions. I cannot find any info in the search function so it must have been on a non SHO related web site. I understand Honda S-2000 owners love it. Has anyone tried this product ? I contacted a local GM dealer and was quoted $ 9.91 per quart, GM direct is about $ 5.75 per quart. Must be a synthetic product for that $$$.
Any comments? Thanks, Mike
SnickterP
Merrick, LI, NY
My freind (and lots of others) with a 90 mustang uses it for his 5 speed. ive never heard of anyone trying it on the sho though. although id imagine it'd work
RI-SHO
B to the BANNED
Pawt., RI
Huntervf used this on his SHO and had nothing but good to say about it.
sholady
Greenwood, SC
We also have a 91 Eagle Talon TSI AWD that we race. This is the best stuff and wounldn'y use nothing else thumbs_u
DeaconBlue
Cleveland, Ohio
If I am not mistaken the guys at Redline make it for Tremec for use in their T-56 trans. I believe it is the same or at least very similar to, their D4 ATF synthetic ATF fluid. I had received a couple of gallons of this fluid as a sample and have it in my '95 MTX right now. It has only been in the trany for less than a thousand miles, but it makes the shifts nice and smooth. The 1st gear syncro is still a bit reluctant at times, but overall much better than with the stock Ford Mercon fluid.
SHO-Canada
Sask, Canada
my friend just put it into his turbo laser... absolutely night and day difference in the way it shifts now.
olympic
Saskatchewan, Canada
I started with Mobil 1 ATF in my rebuilt MTX and it wouldn't shift worth a damn. So I tried the Ford friction modifier and it didn't help. Then I heard about GM synchromesh so I thought I'd give it a shot. Well it worked! She shifts great now.
Be careful when you pick some up though. There are a couple different kinds of GM synchromesh( some have additives and friction modifiers). I believe the proper numbers are:
GM part# 12345349
GM specification# 9985648
Read the labels on the bottle, it should give you some idea of which is the right one.
LaTechSHO
Louisiana
FYI Synchromesh is also available through Penzoil... i know its available through o'reilly auto and is around 3-4 dollars a quart.... i keep it in my store and have used it and love it for all the reasons stated above
Louis
Brad kirk
