malachi
Ok this is what I am trying to do this time....
I have two 12" SPL 1200watt speakers in enclosed box and I have an Audiobahn 800watt amp to push them.
I intend to put into my trunk and wire in with a second battery and dual battery isolator. I have chosen to keep the factory set up and built a box to fit so tight it requires 10-12 swift kicks to get it to snug up really deep in the trunk.
Questions:
A) is there any factory RCA type output jacks in the stock CD/Cassette head unit? If so which one do I have to pull?
B) Assuming that there isn't (from above question), what should I use as an audio source for the amp?
I am mildly mechanically inclinded however I have never messed with audio before this. I was just going to splice into the factory sub and make that work..... any thoughts ....ideas?
Yes I know the talk about extra battery and the weight ...... As I'll be driving with a 100+lbs speaker box and about 150lbs in tools weight is not something I have ever worried about before. I also know that I may end up over taxing my alt...how ever it was already replaced and shant be an issue.
ANY thoughts or input will be taken with gratitude!!!
Thank you in advance.
Malachi
Questions:
Malachi
