Any of you FI guys ever seen this?
SHOguy 92
Duluth, MN
Yep they have it's air to liquid cooling, Josh T who runs SHOnut has a Hangar 18 version of this on his SC'ed SHO. Also you might want to look into your image hosted by angelfire :D
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Actually, that is not air to liquid cooling (or at least not that straightforward).
The SHO pictured on that page is Kaotic's, IIRC.
Lupo
Huntington Beach, CA
This system is water to air intercooler, but it actively cools the liquid to below ambient with the A/C system of the car. It's like putting ice in the tank of a normal water to air system.
The active cooling is not on all the time. What you do is stop the water flow for bit, while the A/C systems chills the water. Once your water supply is chilled,you turn off the A/C, and you are good for a run or two of below ambient temps.
Mike Kopstain
Arlington Heights, IL
You can also run compressed freon from your AC system through the trans cooler portion of your heat exchanger, that is if your heat exchanger has a trans cooler in it. :bonk:
Brad kirk
