Another problem PLEASE HELP!!!
S
SHOFF
Guest
OK i took my car north for a car show, I was driving along and the car hesitated real bad then stalled. It would not start back up, so i went and looked under the hood to check if anything came loose went and tryed it again and it started. Now if i drive it like more than 5 miles it will do the same thing but it will not start until like an hour. And it runs really bad, but if u let it set for a day it starts running good again. I know its something electrical, I thought it was the cps but the tach still goes up when i crank it over could it be a dis module? shoot
Most likely the CPS. Check the codes for the telltale error that would point the finger at the CPS. When the car stalled, did the atach drop immediately to zero even though the engine was still spinning? That would incriminate the CPS.
jedhead
westminster,ca
My '91 showed a steady 300rpm while cranking when my new CPS failed suddenly on me. I just had no spark at all.
Bob
S
SHOFF
Guest
Thanks everybody, I have one here that i was going to put in when i changed my water pump, I wich i would have done it then :mad:
hess_sho
