another idle question
loboreno
NY
I'm having a tough time right now idle is going crazy. I don't have money for a new idle control valve in a 3.0 ..... but I have a spare 3.2 motor with a good one on it they look different but It looks like it would fit and plug in ... do they interchange?
Fordlover96
Virginia
Honestly, if they don't look the same (and therefore aren't the same part) then I wouldn't run the car with it. But, who knows, it could work perfectly fine. Haha
it will fit and work fine. In fact, the ones on the atx are a little different shape and are MUCH easier to get on and off.
loboreno
NY
Ok great thank you guys. Anyone know what the black cap on it is for?
the black cap is just a dust cover.
loboreno
NY
Reason I ask cause , its working fine but at idle , the cap is howling ...low pitch howl or low pitch whistle? ?? Is that normal
no, but its not hurting anything. if you press down on the cap, does it stop?
its probably the cap rattling from a noise that comes from the solenoid inside.
loboreno
NY
I've been busy at school for my cdl a.... ill check over the weekend
Brent
Port Alberni, Canada
I've got an idle question that has plagued me for more or less the 18 years I've owned Bull.
You start him up, drive down the street to an intersection and put in the clutch at the Stop.
Engine idle goes up and down, up and down, and could easily go to stall. At which point it might be infrigginpossible to start up? Without matting the gas pedal until it catches?
Ideas? Hasn't affected the overall reliability of the car, just caused the odd embarsssing moment as it stalls and won't start....
jimtash
nc
TPS or the IAC. Small plunger inside the IAC that controls idle airflow when the throttle body is closed that gets carboned up over time.
