Another idle problem
Smittysshoplus
Utah
Ok first off, I changed the valve cover gaskets and the spark plug seals. Put everything back together started right up other than it idles really rough, the rpms are right around 800-1000 but it, shakes the entire car at idle, as soon as I give it some gas it runs just like it should. I replaced the spark plugs when I replaced the gaskets. I have all ready tried to reset the idle but it still runs rough. Any help???
91_SHOster
Fresno,CA
your Idle air control soleniod could be gummed up, try cleaning that. My SHO was doing the same thing and I used some carb cleaner and it seemed to help out.
