Another foglight question
gimpysho
SNJ
I'm attempting to install my new Hella 20/20 driving/fog lamps this weekend.
The question is regarding splicing into thr parking lights for power source. Is the brown wire on parking lights the power wire. I have downloaded the schmatic. but electronics are my weak point.
Thanks SHO world for you patience
gimpysho
SNJ
I'll be using the Hella switch because these lights have a dual function Fog or driving. The supplied awitch even fits in stock location!
I hope to have better luck.
spazmoid
RI
Hey gimpysho, how did you end up wiring the lights in? Did you use the stock wiring or did you add a wiring harness? And how'd you mount them? Also how do you like the lights cause i'm thinking of picking some up obviously. Thanks
Use the switch connected to the OEM wiring to power a relay. The use the relay to power the new lights.
