Another clutch thread.
whitekysho
Louisville KY
I am doing the clutch on my 91 and was wondering what parts I should replace while I'm in there, I tried a search but found nothing. :thankyou:
yzstud
< my kawi
Minnesnowta
at the very least, i would do the rear main, but its really up to you on all you want to do and how much money u want to spend getting it done
whitekysho
Louisville KY
I was planning on the rear main and oil pan gasket. Are there any bushings in the clutch assembly that might need replaced?
yzstud
< my kawi
Minnesnowta
just a throwout bearing, some kits include this, and some don't. Just make sure u get one either way
38SHO
#1 Oil Abuser
North Palm Beach
yeah axle seals are cheap and the same as a regular auto taurus....
rear main seal, rod bearings, oil pan gasket kit, oil filter, oil, drain the tranny while its out, tilt it so the fill plug is at the bottom and it all drains for awhile... then fill it with some regular Dexron/Mercon III fluid
might want to have a spare exhaust donut for the end of the y pipe to the catback... sometimes u can break it if its already bad from the get go....
whitekysho
Louisville KY
I'm ordering the ceramic tob.
Yes the donut is already leaking a little. Thanks everyone.
itwonder
VA
It's a good time to replace the coolant hoses that are right above the transmission because they are easy to access.
93rev2sev
Hockeytown
Well,
Since the y-pipe and starter are out...how about replacing the oil cooler to block gasket? You can use the gasket thats on your OLD oil filter...it should be a perfect fit.
itwonder
VA
I thought the MTX calls for Synthetic Mercon ATX fluid?
See thread in Product Feedback forum. Those of us who have tried conventional Valvoline Dex/Merc ATF from NAPA have seen improved shifting performance. Ford does not specify synthetic, although Mobil 1 ATF was a popular choice until the Valvoline revelation.
