Another aftermarket discovery on my SHO
DARTHSHO
South Florida
today I put the car on the lift after I balanced and rotated the tires and I looked up and did a double take I have catless down pipes and never knew it. No codes and no tune. Now knowing that this was a former detectives car I’m interested in knowing if police departments use non catted DP. Every day I learn more and more about this car
Jordan_R
Missouri
Lol, pretty good find! Does it have defoulers in place? And you sure on the no tune?
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
looks like someone modified, those are either OBX or gen 1 Stainless Works downpipes, you can tell by the front O2 having to be relocated to clear the ptu cooler.
Time to take a peek at the map sensor and check the part number as compared to the one in front of the throttle body. If they are they same, you're tuned. You can also use Torque PRO and an obd dongle to check boost.
DARTHSHO
South Florida
i was about to take the map sensor off to see if it is a 3 bar o not and I noticed it was missing a screw lol so not messing with it now
FiveLeeter918
Tulsa, OK
that's normal, once you remove it you'll find there isn't even a hole in the manifold for the second screw.
And yes, that is a 3 bar map sensor...
DARTHSHO
South Florida
Sweet today news getting better and better lol I was going to buy a 3bar I’m scratching things off my list to get.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
I wish mine came that way! Nice find! Is already being tuned an issue trying to install a new tune if not the same software? I know I had to tune back to stock when I was LMS Tuned and before I could switch to SCT and AJPTurbo. Need to be stock to get strategy ?
FiveLeeter918
Tulsa, OK
Depends on if the tuner masked the strategy or not. Sometimes it's still available and we can just tune over it, and the new handheld just saves the stored tune file as stock. If you have a hook up at the dealership, usually best to use IDS to recover the stock file since we don't know what all was changed in the calibration and sometimes things don't mesh up properly.
802SHO
Hopefully he doesn't run into an issue with already being tuned, trying to get a new tune.
FiveLeeter918
Tulsa, OK
Can be done, just have to make sure the tuner knows that they need to force a complete calibration and not just the change file that is typically sent out. When Luis did one for Thayne Bader after his HPTuners dyno tune fiasco it took literally 45 minutes to force overwrite the entire PCM.
802SHO
Damn, that's quick! I figured it could be done, just assumed it would be a huge pain in the ass process.
DARTHSHO
South Florida
If I look at the stamp o. The transmission. The code is there on it. When I plug it into FORScan the same code should be there if it’s not then it has been tuned. Unfortunately I can’t get it on a lift to check the transmission for two weeks :( o well at least now I know
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Mine would not run or hold idle with tune and 2 bar. Matter of fact it would stumble around and sound so bad it would hurt my feelings...
DARTHSHO
South Florida
So I plugged it in and now I’m a little scared wtf is Chinese doing in my American car?
Brad kirk
