LoL if it's the sony explod 1600 that you have in ur sig, well thats the problem. Dont even get me started on those things. I blew up (internally) 7 of them literally. 7 amps in 2 weeks. At least sony didn't lie about the name Explod!!!! But if you do want to keep that amp and TS your problem I need to know a little more about your setup. Like what do u mean by turn it on high? What kind of subs? What Ohm load are you showing to your amp? What kind of wire are you running?(gauge) Do you have a solid ground? Hows you alternator? Are you getting any clipping from your rca's? There are so many variables with a protect light comming on. Has this problem just started happening,was it fine before this? If so how long? But if I had to take a shot in the dark I would say either your showing your amp to high of a load,and its going into protect. That or you have the gain turned up to high your voice coils are heating up and sending you amp into protect. But without being able to look at it I cant really do much more than guess. But I do have a qusetion for you do your headlight covers cover the sidelights also because it dosent look like in those pics or is that just a glare I see?
