Diameg
I am still having problems with the LPM/80mm combo. My concern at this point is if I'm doing any damage to my engine.
Background: With my 80mm and LPM on, the idle is sometimes erratic, fluctuating between 600 and 1000 rpms. Very annoying. I have tried 4 different MAF's to no avail, plus the LPM has been reprogrammed twice. The IAC is the correct voltage and I have tried 2 cleaned IAC's and one new one. Didn't help.
Pinging?: I still don't know what pinging is. I know the description but since I haven't officially heard it on another car, I don't know if my car is doing it. There is a 'rattling' sound above 2000 rpms and below 4200 rpms at WOT in first and second. I don't hear it in any other gear. I suspect it is not pinging because I don't hear it in the other gears at all. I suspect it is perhaps a rattling heat shield on the cat, or something like that. Could I be gravely mistaken even though it is not in the other gears? It seems to be under 'violent' acceleration, hence the car shaking, hence my conclusion. I can duplicate it to a lesser degree under, say 3/4 throttle, again only in the 2 lower gears.
Real Problem: The car stalls sometimes when I'm changing gears, especially downshifting while slowing down. Example, when downshifting preparing for a turn, it may stall. Or, coming to a stop and just throwing it in neutral, it may stall. Sometimes its fine, other times the revs drop to the point of stalling. Sometimes it catches itself, sometimes it doesnt and just dies.
My concern is that the oil light comes on just as it's about to stall of course. I know that's not good but if it happens once in a blue moon, no biggie. But the revs are dropping to the 'almost stall/stall' point pretty well every other time I put the clutch in. Is this killing my engine??
Any ideas on what else I can do other than just getting a re-burn of the LPM? I'm guessing no. Would I be best to ditch the 80mm and go with a Pro Flow? If so, which one?
Sorry so long. Actually, I'm not really. I'm so fed up with this that I welcome any and all advice, even if it's Kirk suggesting that I ditch the LPM and just go with the 80mm (doesn't run really strong that way either).
Mike
Mike
