Aluminum SFB dimensions
Blast7
Rochester, NY
Does anyone have the dimensions of these? [email protected] Also, how come no one has ever used any stainless steel to make them? I'm assuming it's because aluminum has worked fine but I am curious.
slapnpop
Johnson City, TN, USA
I found the measurements that were posted, and have a set on the drawing board for next week. If they work out well i'll post plans/files.
[email protected]
Albany, OR - USA
Porod:
You site says "page removed pending discussion with designers of plans"
This is correct. Due to a bit of debate regarding my posting of the plans, and the issue of ownership of said plans, they have been removed.
For the record, someone is developing a set of aluminum bushings with rubber or Delrin isolators and has said that they will make the plans available. I truly believe these will be a much superior design to the two I had previously posted.
As soon as these are developed, and the plans are made available, I will post the plans and advertise them here.
