Alternator Output Control Relay 89 and 90 the same?
shorage
Marshall, VA
Good evening y'all.
So i was curious if the Alternator Output Control Relay is the same for both the 89 and 90?
I attached snapshot of the 89 and 90 EVTM regarding this item but it is not clear if it the same part number.
I am rewiring my 89 with a 90 harness and i think i forgot to pull this item. Thoughts?
Thanks
Frank Costa
89 with a 90 nervous system
BaySHO Performance
SF South Bay
Pic 1 is for a 2.5l engine, not a SHO. The component diagram is for a SHO which shows an alternator output control relay, but it actually doesn't exist.
shorage
Marshall, VA
No, im swapping a 90 harness into my frankenstien 89 SHO. The dash is a 90 and a long time ago in a state far far away i created an adapter using donor harneses to adapt the 90 dash harness to a 89 engine bay harness. i couldn't get the gauges to work. I figured its faster to just swap the harness. But i could be wrong. LOL
Well keep us updated on that. Sounds like not fun! but maybe useful considering wiring issues at this age
shorage
Marshall, VA
So far so good, created new post with updates.
https://shoforum.com/index.php?threads/90-engine-harness-to-89-engine-connectors.139898/
Please reply on there if you can, Not sure if i linked it correctly.
The following is from that post
Need 2 connectors to make an adapter. I am wiring a 90 "engine harness" to the 89 engine connectors. I need to create an adapter. Which is preferred to splicing into my "new" harness. Anybody have these? I would call them female connectors. I found the black one but i am not paying 80 bucks for it.
Apparently, they swapped from Male to Female on the "On Engine Harness" from 1989 to 1990
Just for clarification. I see 4 harnesses.
1) Dash Harness (out of firwall)
2) Light Harness/ABS/Airbag Harness
3) Engine Harness (Around engine and connects CCRM
4) On Engine Harness (sticks out the bottom of the throttle body into the valley)
I am sure i am naming them wrong, if anyone know the names, i will refer them to the proper names.
https://connectorexperts.com/i-24488497-ce8015f.html…
shorage
Marshall, VA
Well, its running, at first i thought my adapter was poo poo but i swapped the 91 MTX - L0S pcm in place of the 89 B9B i had in it and it fired right up.
