All wheel drive and spare tires
Laramie Brown
Denver co
What are the effects of driving with a spare tire had a blow out on the highway was forced to use the doughnut on the rear
Sent from my SM-G900V using Tapatalk
The AWD system should disable if it detects a problem, and revert to FWD. Since the spare is on the rear axle, should not have any permanent issues, full function being restored by a normal sized tire being installed. Traction and handling will of course be negatively impacted until then, there is some compensation by the safety systems, but drive more conservatively until the spare is back in its' roost.
Glad there was no damage during the incident!
Johnbigdog
michigain
If you are running one dissimilar circumference tire on one axle, the differential spider gears will take up the difference.
Problems come in if there is a large difference between the front and rear axle tire circumference. You will get driveline windup if the awd system activates. This is kind of a bucking sensation if you've never been in a truck in 4x4 high on a dry road surface.
