ALL the codes
zblackbeast
SHOtarded
Omaha, NE
Ok, first off it gave me a 111 which is system a-ok but its not...
then i got what i deciphered to be 211 which is Ignition PIP signal was erratic or missing - Ignition Systems
that would cause the non idle... but how do i solve this??? and lastly i got what i believe is a 542 or fuel pump always on..i wish i had someway to take video.. Ill see what i can do. let me know guys!! thanks
Clay
haggarSHO
Shreveport, LA
211 is crank sensor as i have just figured out, and why my car dies randomly.
542 will be thrown when your car stalls.
so new crank sensor, 60k time for me
zblackbeast
SHOtarded
Omaha, NE
it would stumble at at idle then stall out
would that throw the code?
would the crank shaft sensor cause it to stumble and stall out?
how big of a PITA is it to replace?
hawkeye18
Sorta cares
Norfolk, VA
stumbling at idle is 90% of the time one of two things:
1) bad ground... this includes the strap that goes to the back of the intake, AND the wire that goes to the negative battery terminal.
2) bad IAC... clean it and/or replace it.
The crank sensor is a PITA to replace if you've never done it before. search the words on the forum and you'll find a bazillion threads on how to do this.
