Airbag electronics - need module for 95 SHO
dave.depue
Kansas
My 95 has a flashing code 51 for the airbag.
The diagnosis seems to be a burned fuse link in the module.
My mechanic says that the module board needs to be changed.
Anyone have an extra one for sale?
Next best hope is to check salvage yards.
Wonder what years Taurus used the same airbag module?
Thanks for your help!
kevinspann
Don't take my advice.
Richmond VA
I should have one, but I don't know for certain what year it is off of. Its either 94 or 95. It should make no difference though, the air bag setup is the same. Ill get the part number off of it, and you can compare it to yours.
dave.depue
Kansas
airbag electronics
thanks kevinspann
The Ford mechanic plans to change the module on my 95.
Soon as I can find one.
I saw an earlier post cautioning about a module change without finding the reason for the burned module fuse!
dave.depue
Kansas
95 electronics module F2DF18C808AB
My 95 has a module part #:
F2DF18C808AB
An earlier posts suggested that the fuse may burned out when there is an intermittent ground connection. This results in the air bag light flashing a 51 code. Guess I had better try to check the ground connections first.
Might be able to get a module from a salvage yard - should be the same for a taurus.
Thanks for any advice on this
Dave
oldkat
1992 SHO
Missouri
I have the 51 airbag code on my 92 SHO. Where is ithe module with the fuseable link at? Does anybody have a picture of it or the location?
jonheese
Used-To-Know-It-All
Fogelsville, PA
It's a bright blue box behind the glove compartment. Open your glove box and push inward on the two sides where the rubber stops are. It will continue to fall forward (you will want to empty out any contents first) and you will be able to see behind it. You should see only one bright blue object there. That's the airbag system diagnostic module.
The exact same part is used in tons of other FoMoCo cars with dual airbags around the same era. Taurus, Sable and Thunderbird for sure, most likely Mustang, Continental, Crown Vic, etc also. I think it's even the same across Gen1 and Gen2 airbag-equipped Tauruses, so it might not even matter if it's dual or single airbags. If the connector is the same, it will work. You can get one from a junk yard, just make sure that the donor car hasn't fired its airbags, as the thermal fuse usually gets blown during an airbag deployment event.
If you know how to solder, you can replace the thermal fuse in your box, and I have done it successfully. But as you mentioned, make sure to locate the fault that caused the short (the most common cause in my experience is a bad clock spring in the steering wheel) before replacing anything, otherwise you will just have another blown fuse right afterwards.
To replace the thermal fuse itself, you'll obviously need a new one (Radio Shack part# 270-1322, available at most RS stores that have an electronics components section).
When you open up your airbag module (the blue box), you'll see a small black and white plastic box on the circuit board. Carefully separate the halves of that box, and it will open. Inside you'll see the thermal fuse, most likely it will be burnt looking; that is normal and that means that it did its job. De-solder it from the board and replace it with the one you bought, soldering it to the board in the same place. Then put the black/white plastic box around it, snapping together the halves. Put the board back in the blue box and put the blue box back in the car.
It will make sense once you look at it and read this, trust me.
Good luck!
jonheese
Used-To-Know-It-All
Fogelsville, PA
The green-tipped thermal fuse is the correct spec for this repair. I was looking at my notes wrong on that one... Can't find it on Radio Shack's site, but you can probably find them there-- or just buy the one on Amazon. :)
Also, that PDF is a GREAT resource for this procedure, including the troubleshooting process. It shows in pictures exactly what I described above. Thank you oldkat for posting that!
