kjlookinup
About a month ago, my 95 SHO started to give an airbag code 42. Finally, I've gotten the chance to work on it... learned a lot, but still have the code. Some questions:
1) Is this the sensor just behind the radiator or in front of the windshield? Both locations have been referenced for this code on the forum.
2) I've followed the procedure given here and found the sensor to be good - resistance less than .5 ohms. With the sensor connected, the circuit is open at the airbag monitor. I've checked the plugs at both ends, both yield very low resistance... seems like there's a break in the wiring somewhere in between. Where does the circuit physically go between the sensor and monitor? Are there any other plugs which may be corroded? Thoughts on troubleshooting the circuit would be welcome.
