Airbag Code 35
strykr14
Michigan
Hey all,
So my 92 Airbag light started flashing 35. An online search told me this - Code 35 (triple flash, pause, five flashes) means the passenger side airbag has a shorted circuit or one with low resistance.
Any idea what I would do to fix this? Do I need a hammer?
note that when the airbag light flashes, the airbags will not deploy. even with a hammer.
so you either have a short in the circuit to the passenger side airbag, or the airbag itself has shorted. you can access the connector to that by dropping the glove box door down, iirc, and disconnect it to see if the code changes.
