Air Bag Light Flashing
eacyde
Pinkley Taurus
Calgary, Alberta, Canada
My air bag ligh started flashing out of the blue last nite,
It is flashing 3 times, then 2 times.
I tried to search for what that means and came up empty.
Please help.
Diagnostic Trouble Code Table 1994
AIR BAG DIAGNOSTIC MONITOR DIAGNOSTIC TROUBLE CODE PRIORITY TABLE
Priority Code Component/Fault Description
Highest - No Air Bag Indicator - Inoperative Lamp Circuit or No Ignition
Voltage to Air Bag Diagnostic Monitor
Continuous Air Bag Indicator - Air Bag Diagnostic Monitor
Disconnected or Inoperative
12 Low Battery Voltage
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Safing Sensor Not Mounted to Vehicle Properly
22 Safing Sensor Output Shorted to Battery Voltage
23 Safing Sensor Circuit Input Feed/Return Circuit Open
24 Safing Sensor Output Feed/Return Circuit Open
32 Driver Side Air Bag Module High Resistance or Open
33 Passenger Side Air Bag Module High Resistance or Open
34 Driver Side Air Bag Module Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Module Low Resistance or Shorted
42 Center Radiator Primary Crash Sensor Feed/Return Open
44 Center Cowl Primary Crash Sensor Not Mounted to Vehicle Properly
45 Center Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
51 Diagnostic Monitor Internal Thermal Fuse - Fuse Blown Due to
Intermittent Short to Ground
52 Backup Power Supply - Voltage Boost Fault
53 Primary Crash Sensor Circuits - Resistance to Ground or Air Bag
Diagnostic Monitor Failure
Lowest - Rapid Continuous Flashing of Air Bag Indicator (No DTC) All Primary
Crash Sensors Disconnected
DIAGNOSTIC TROUBLE CODE 32
Driver Side Air Bag Circuit High Resistance or Open
Normal Operation
The air bag diagnostic monitor measures the resistance across Pin 10 (Circuit 615, GY/W) and Pin 11 (Circuit 614, GY/O) every time the ignition switch is turned to RUN. Normal resistance across these circuits is between 1.5 ohm and 2.0 ohms. This resistance comes from the air bag itself (approximately 1.0 ohm) and the air bag sliding contacts windings (approximately 0.25 to 0.5 ohm per winding, two windings in all). If the resistance across these two circuits exceeds 4.0 ohms, the air bag diagnostic monitor will flash code 32.
NOTE:
The connectors for the driver side air bag module and the air bag sliding contact have metal spring clips that act as shorting bars. These shorting bars are built into the plastic hardshell connectors. The shorting bars are designed to short Circuits 614 and 615 together when the connectors are not mated. DO NOT attempt to remove the air bag shorting bar and measure the resistance of the air bag.
The air bag sliding contact shorting bar may be removed to measure the air bag sliding contact resistance. Use extreme care when reinstalling the shorting bar to ensure it is installed correctly.
Possible Causes
Excessive resistance across Pins 10 and 11 can be caused by:
29. A poor connection where the air bag sliding contact connects into the main wiring harness. The air bag sliding contact connector at the base of the steering column may have excessive resistance between the male and female terminals in the connector or across the terminal crimps.
30. An open circuit or high resistance in the air bag sliding contact windings inside the air bag sliding contact assembly.
31. An open circuit or high resistance in the wiring harness in either Circuit 614 (GY/O) or Circuit 615 (GY/W).
32. An open circuit or high resistance in the driver side air bag module. DO NOT attempt a direct resistance measurement of the driver side air bag module. Follow the diagnostic procedures to determine if the driver air bag resistance is higher than normal.
tardboy21
Woodbridge, NJ
mine does it every now and then. threw it today too. I shut the car off and restarted it and it stopped. I'm thinkin it is just my connection. I will get around to checking it eventually.
