ahhh! my horn dosent work!!!
SHO_DOODmorrris
Owner & Fanatic
Alberta
This sucks... went to go ream somone out last night for cutting me off and it dident work... quick drop to second from 5th let them know i was there though:evilgrin: all fueses are ok and it also dosent work... wait a sec. the fuse inline with my alarm system might be the culprit hold on.
Phoenix
SHOHOLIC
QC , Canada
The cruise/horn thing are only for ATX's.
Id start with a multimeter at the horn connector , if there's 12V when you press it , you need some horns.
If not , could be the clock spring. It would explain the cruise.
spazmoid
RI
when this happened to me i just cleaned the connections on the horns. They were corroded and so the horns weren't working. Your in Canada right? So there's probably some rust under there.
SHO_DOODmorrris
Owner & Fanatic
Alberta
Watch it eh... canada isent the only place where there is rust :p yeah but my cruise dosent work as well and i did an interior swap with a 91 so it has a different wheel and it is possible that the wheel got turned before it got bolted up. so i doubt both buttons would go at teh same time as well.
-M
SHO GoDz 89
True Sleeper
Monroe Twp, NJ
I had the same problem with my MTX.
Horn and cruise would only work if I turned the wheel to the right or left.
After a while that didn't even work though.
