ScottyDsntKno
Did some searching, once again came up blank. Found lots of questions about temp gauges themselves but nothing on the install. I know the stock sender is near the tstat housing but not exactly where although I can probably find it. The question I have is how accurate is it and can you bug an autometer gauge off it? I know probably not but it'd make it a lot easier to install an aftermarket guage by just splicing.
If not then I'm going to use a mechanical autometer phantom gauge and have the filler neck drilled/tapped for the stock sender so can plug it in there and not have a dead gauge in the stock cluster. This is what I did with my Cobra and it worked like a champ although with those you can get filler necks already tapped for the sensor. I'll post a how to if I have to do that but like I said, much easier to bug an electric gauge right into the stock wire if possible.
