aftermarket stereo wiring
benjammin
washington st.
I have a 93...Am I right in saying that the yellow w/black stripe is the accessory, and the blue w/black stripe is the antenna?...The JVC stereo Im installing has an illumination wire that goes to the cars light control switch, What wire does that go to?
SuperHO
Mental Patient
St. Joe, MI
yellow/black i'm pretty sure is the 12v source, and iirc, the red wire is 12v switched. why are you hard-wiring instead of using a harness? especially without a wiring diagram in front of you?
deercrusher
never running!
PA
my suggestion to you would be as stated in the above post. Get yourself a stock wiring harness - wire to your stock wires - matching colors, Then get yourself an aftermarket harness to plug into the stock harness, If you are going with an amp bypass setup there is already a harness for that in the sho - look to the left side in the din hole - that unused harness can be used for running an aftermarket stereo with the stock amps removed.
