OrwellianChild
Well, I feel like I only post when I've got an issue, but all of you have been great in walking me through my SHO issues... Here's the next step in the saga:
I'd been getting CELs on and off, culminating in a couple of engine stalls on the freeway... Upon recommendations from this forum, I did a 60k in-house (SPP Guide was very helpful, as was Fred for providing parts - thanks!). I swapped the water pump and gaskets, timing belt, crank seal, cam seals, Crank Pos. Sensor and Cam Position Sensor. Flushed the radiator fluid and swapped the lower rad. hose as well... The seal behind the Cam Pos. Sensor was bad, so I figured I had solved things by replacing them all.
No dice. I just got the above codes all over again. I'm wondering what my next move should be... Any suggestions? Thanks for all the help!
