9
94ShoOff
Guest
Had the 60K done on the 93'Atx and got it back and found it leaking oil. Put dye in the oil and found the rear valve cover gasket leaking. The guy replaced the gasket and found a slice in it, apparently causing the leak. Got it back, and it still is leaking somewhere. Other than the valve cover, could it be somewhere else? Is it possible for the actual valve cover to be causing this?
Steve
94'ShoMtx, 91'Sho,87'Grand National(modded),97'NinjaZX7R,90'Grand Am Se
Wifes cars: 93'ShoAtx(fresh 60K service, $ ouch), 91'Corvette Conv.
Steve
