Oil leak
jacoby
Michigan
I have a 93 atx with the 3.2l and I have a oil leak right by piston 1 and no clue what it could be. Also I have already did a compression test.
jacoby
Michigan
I already replaced valve cover gasket but I will check the cam seal thanks
Irish Pride
Irish Inside
MusicCityUSA
It is very common to roll the rear valve cover gasket if you are not very familiar with the job. Use a small mirror to look behind the valve cover and make sure you seated the gasket correct.
-Chad
