Aeroforce 2010+ Taurus gauge pod install
Randy Marange
FHO SHO
New Jersey
Hey guys. Just received my Aeroforce gauges and Aeroforce gauge pod today for the Ford Taurus 2010+. This install was fairly easy. Took me about an hour or so to install it.
Here is a guide as to how I went about installing the gauges and gauge pod into my car.
First and most important I READ the directions. Probably one of the most important steps before doing anything to your car!
Next I took the gauges out of the packaging and fitted them into the gauge pod. One hiccup I found in this was the bracket that holds the gauges into the pod were too big for the gauge pod. So what I did was take a hacksaw and cut the bracket in half and one of the halves I had to trim down a little more on the "leg" part so I can secure the gauges to the pod. 20190425 173343
Next I made sure everything was lined on on the face of the pod. (I went with the extra $10 and got the carbon fiber face plate with the SHO logo in it. The gauges come with a black and white face automatically.)
20190425 173336
Next I took off my center speaker panel on the dash and with the diagram provided I drilled 1/4" holes per the diagram. (One thing I noticed was the diagram is actually backwards. It shows two hole locations. One for even with the center of the dash and one for slightly towards driver. The driver holes were actually on the opposite side on the diagram so I just drilled equal distance fro the canter holes to the other side.)
20190425 173402
After you drill the mounting holes I them drilled a 1/2" hold in the center for the gauge wires to go through.
20190425 180258
After that I removed the speaker and drilled another 1/2" hold on the outskirts of the speaker hole. (One thing I should have done was drill it to the bottom and not the side so the wires underneath don't bunch up)
20190425 175328
After that comes the tricky part. Running the wires. For this I had to remove the panel underneath the steering wheel with a 7mm socket (There are two bolts on the bottom). Then popped it off. After that I then removed the small air vent panel next to the ignition button so I could run the wires.
After removing the panels I took a wire coat hanger and ran it straight up the dash and pulled the wires through. Be very careful as to not rip the wires when pulling them through. It is a very tight space and this probably took the longest time of the entire install.
20190425 175403
After that you then run the wires up through your hole you drilled next to the speaker and then reinstall the speaker.
20190425 180203
After that you can then run the wires through the center hole on your speaker panel and connect them to the gauges. I then plugged them into my OBD2 port to make sure they were working properly.
You can then connect the gauge pod to the speaker panel and make sure it is snug to the panel and isn't loose.
After that I bundled the wires up with a couple zip-ties and placed them behind the metal dash panel under the steering wheel.
20190425 180804
Once you are done reinstalling the panels you took off you can them plug the gauges in the the OBS2 port and start your car.
They will take you through a small set-up where you can mark what parameters you want to be read on the screens.
Once that is done you are ready to go and enjoy your new Aeroforce gauges!
20190425 182225
SaveMelMac
Texas
On my install I didn’t use the brackets I just wrapped some type around the outside diameters of the gauge and pushed them in the pod. Will make it easier to remove the gauges in the future. But nice write up
sanman
803603ED D7E3 437C 8A03 AA3001D0B315 Just got my gauges back from Aeroforce with the new parameter screen display 8 separate parameters displayed at once. They work great..
Randy Marange
FHO SHO
New Jersey
View attachment 9056 Just got my gauges back from Aeroforce with the new parameter screen display 8 separate parameters displayed at once. They work great..
I like that!!
I had to send one of my gauges back the day after I got mine because one was bugging out and not working properly. Hopefully they can figure out what was wrong with it
sanman
I like that!!
Yeah mine were freaking out too, i sent mine back a second time all is good so far. "
Fingers crossed"
dinojc86
New York
Right now I'm running boost, a couple engine temps, and a couple other parameters I change through. If you go on their website you can see what parameters will read on the gauge for your specific car. I put the link below. Hope this helps
https://www.aeroforcetech.com/products_interceptor.html
Reading the info on the website, this technology is amazing; just plug and play.
I am old school and just amazed what these gauges can do............
Thanks for the info.
DouglasB_SHO
Former owner 2011 SHO
Sagamore Beach, MA
Too bad they didn't offer a glare shield to shade the MFD just below. I'm still using a matte black binder cover I cut to the right shape to slide into the gap after I bought my 2011 SHO in 2012. If I was into 3D printing, I would have tried to make a custom sunshield to fit between the two upper dash projections. Anyone have a better solution?
myculito
