Accumulator Line....is it good?
shorage
Marshall, VA
Hello all, im trying to get my ac system in COLD condition.
I have purchased a motorcraft accumulator line maybe 2 years ago. It is new and in the garage. Unfortunately....the caps have been removed from it. It isnt sealed tight.
Is it still safe to use?
I read somewhere that you dont want the accumulator line to be exposed to air.
It has been in the garage the whole time...just uncapped.
Have i saved this part for no reason? Can i use it? or am i gonna have to throw aware a brand new $140 part into the garbage?
Thanks in advance everyone.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
The dryer's main function is to keep moisture out of the system and with it being uncapped, it has absorbed moisture. Toss it and get a new one. They are fairly cheap, so best to just get one new again
Storm-Chaser
Shit Louis
I'll second that !
You might first try taking the accumulator to a "reputable" local air conditioning shop and ask if the drier/absorbent can be treated or replaced.
Even if it can't, do not throw it away :nono:, as it can serve as a pattern to have a new accumulator/drier hose assembly made.
Let me know what you find out, I may be able to help. :thumb:
clindahl
Raleigh, NC
not to put a plug for a parts dealer, but
www.partsamerica.com (Advanced Auto in my Area)
Part No.
55620
Accumulator/Reciever Drier; w/Suction Hose; R12 Or R134a Compatible
$97.48
That part is installed and working on my 1993 SHO which was R12 from the factory and when I needed to fix a leak, changed out the liquid line and the reciever dryer and loaded it with 134a. Works fine.
