Acceleration/shifting issues
SHOCALL
STL
Sorry thought that was a given. And theyre just that. Rims that you use in the summer. In cold climate areas we tend to have a winter set that isn't as nice cause it tends to get torn up and smaller in order to have taller tires then people run low profiles with bigger rims in the summer.
2010 SHO PP, axle back exhaust, 3 bar MAP, upgraded thermostat, iTSX tuner, 20" summer rims wrapped in oversized Advan Sports
Copy
Ryan Selcer
Colorado
Got any pictures of the car?
Had a ****** weekend and didn't get a chance to take any, dont see how that is gonna help this situation what are you looking for?
2010 SHO PP, axle back exhaust, upgraded thermostat 20" summer rims wrapped in oversized Advan Sports (currently removed 3 bar MAP, iTSX tuner with 91oct tune)
Michigan-SHO
Michigan
Really just anything out of the norm in the engine bay or something. Just trying to get as much info as possible to help you out.
Ryan Selcer
Colorado
Ok give me a bit let me try to run out before work
Ryan Selcer
Colorado
I dont see anything else other than the noisemaker delete02dbcadf7056d7613fce7322984c1d5e952d0609581bf291d090aaa4c4690d74
Ryan Selcer
Colorado
I believe this is the recirc line that he removed to have the blow off sound?8e94c03bac27e64f10936a372a7f55da
Ryan Selcer
Colorado
One more of the noisemaker delete641ca15f1ccc72f80502d69041433a71
There is that one and another near the firewall.
Ryan Selcer
Colorado
Is it possible to just replace them with BOV? I take it the oil is from not having a catch can?
They are BOVs, and yes invest in a CC. If you buy the EPP Hot Pipe you have the choice of upgrading to a single Tial BOV. The stocks ones work just fine however.
I pull this out of my CC every 3k miles. Without a CC that gets sent back into the intake tract and then baked onto the valves.
20181104 075148
Ryan Selcer
Colorado
Sorry meant to say aftermarket BOV. Like will I need a tune or anything for an aftermarket one?
There is not a direct upgraded aftermarket BOV's for our car. You could get the EPP Hot Pipe kit and go that route.
Or you can get a the EPP noisemaker eliminator pipe and have an aftermarket BOV fitted to that. However you will need to get some block off plates for where the stock BOVs mount.
Michigan-SHO
Michigan
What about the electronics hooked to the stock BOV’s? If you switch to an aftermarket single BOV where are you plugging the stock electronics in at?
Ryan Selcer
Colorado
That was part of my concern too
they probably just become *************. Swinging in the breeze.
If you get block off plates or go with the hot pipes, most people just leave them plugged in and zip tie them back out of the way.
Ryan Selcer
Colorado
When i get into all this I'll see if i can make a shorting plug or something
