AC service master parts list
Irish Pride
Irish Inside
MusicCityUSA
I thought that I had already posted this but I can't find it. Enjoy!
Compressor - Nippondenso Model 10P15F
Ford - E9DZ-19730-A / E9DH-19D623-AA (YC61)R12
Ford - F1DZ-19703-A / F3DH-19D623-CA (YC105)R12
Ford - F4DZ-19703-B / F4DH-19D623-AA (YC173)R134
Aftermarket - Four Seasons #57365
*MTX and ATX use the exact same compressor. Only difference is the different seals required for R134
Compressor/Manifold O-rings for 134a
Four Seasons/Murray #24621
Compressor shims -
Ford E9VY-19D648-A (YF1658A)
Clutch Gap. 020"-.035"
Compressor Clutch -
Ford #E43Z-19D786-A / E43H-19D786-AA
or E43Z-2884-A
Motorcraft #YB289A or YB289
Compressor Hub/Pulley -
Ford #E43Z-19D784-A / E43H-19D784-AA
or E43Z-2E884-A
Motorcraft #YB314A or YB314
Compressor Coil -
Ford #E9DZ-19D798-A / E9DH-19D798-BA
or E9DZ-2987-A
Motorcraft #YB367A or YB367
Accumulator/Drier -
Ford 3.0 E9DZ-19C836-C / F3DH-19C913-CA (YF1976)
*Replaced for 94-95 F4DZ-19C836-B / F4DH-19C913-AA (YF2072)
Ford 3.2 93 only F3DZ-19C836-B / F3DH-19C913-BB (YF2002)
*Replaced for 94-95 F4DZ-18C836-C / F4DH-18C913-CA (YF2073)
Superseded F4DZ-19C836-FA / F4DH-19C913-FA (YF2764)
Aftermarket - Four Seasons #55620 89-93 w/3.0, #55641 94-95 w/3.0
Refrigerant Hose/Liquid Line/Orifice -
Ford 3.0 1989-1995 E9DZ-19835-A / F3DH-19N651-CA (YF1575)
Ford 3.2 1993 only F3DZ-19835-A / F3DH-19N651-DB (YF1802)
*Replaced for 94-95 F3DZ-19835-DA / F3DH-19N651-DB (YF2491)
Aftermarket - Four Seasons #55722
Suction Line/Manifold -
Ford 3.0 1989-1993 E9DZ-19E636-A / E9DH-19E636-AA (YF1573)
Superseded F3DZ-19E636-B / F3DH-19E636-BA (YF2022)
*Replaced for 94-95 F4DZ-19E636-A / F4DH-19E636-AB (YF2062)
Ford 3.2 1993 only F3DZ-19E636-A / F3DH-19E636-AB (YF1971)
*Replaced for 94-95 F4DZ-19E636-B / F4DH-19E636-CA (YF2199)
Discharge Manifold -
Ford 3.0 1989-1993 E9DZ-19E574-A / F0DH-19E574-AA (YF1572)
*Replaced for 94-95 F4DZ-19E574-A / F4DH-19E574-AC (YF2058)
Ford 3.2 1993 only F3DZ-19E574-A / F3DH-19E574-AC (YF1972)
*Replaced for 94-95 F4DZ-19E574-B / F4DH-19E574-BB (YF2059)
Discharge Hose -
Ford 3.0 1989-1993 E9DZ-19972-A or E9DZ-19972-B / E9DH-19N649-AE (YF1574)
Superseded FODZ-19972-B / FODH-19N649-AA (YF2021)
*Replaced for 94-95 F4DZ-19972-A / F4DH-19N649-AB (YF2063)
Ford 3.2 1993 only F3DZ-19972-A / F3DH-19N649-AC (YF1973)
*Replaced for 94-95 F4DZ-19972-B / F4DH-19N649-BB (YF2064)
Aftermarket - Four Seasons #55920 89-93
The part number with fourth digit "Z" is the Ford catalog number. The part number with the fourth digit "H" is the engineering number. This will be the actual number stamped on the part. The "YB" part number is the Motorcraft number. These are the parts that could be bought from retailers other than the dealer.
* denotes the change to R134 for the 1994 model year. The only difference is the seals/o-rings required for use with Pag Oil. Otherwise, the parts are exactly the same. For example - An 89 Accumulator can be used on a 95 as long as the correct o-rings are used.
Fish302
Phoenix
Compressor shims -
Compressor Clutch -
or E43Z-2884-A
or E43Z-2E884-A
Compressor Coil -
or E9DZ-2987-A
Accumulator/Drier -
Discharge Hose -
Thank you! Gotta get this sorted before the brutal AZ summer hits...
Larry N Johnson
Saratoga Springs, UT
Compressor shims -
Compressor Clutch -
or E43Z-2884-A
or E43Z-2E884-A
Compressor Coil -
or E9DZ-2987-A
Accumulator/Drier -
Discharge Hose -
We are looking for A/C parts supply for Gen 1 SHO, 1989.
Will these parts fit? Specifically, the compressor listed.
Kebabaluba
Norway
How much AC refrigerant and oil does my 93 SHO need? I plan to drain and refill my AC system as i have barely any service history on my car.
Irish Pride
Irish Inside
MusicCityUSA
If doing a complete system flush/overhaul, it takes 32oz of 134 Refrigerant and 7oz of Pag oil. Motorcraft YN12 Pag oil is equivalent to Pag46 but I've seen others use Pag100. I personally use the Motorcraft YN12. You want to put 2-3oz of oil into the compressor and the remaining 4-5oz in at various other points in the system. Condenser, accumulator, evaporator, etc...
If you are unsure of the history of your system then you want to flush the compressor several times on the bench. Use fresh oil and rotate the compressor by hand several times. Drain and repeat over and over until you get nice clean oil coming out of it. I use brake clean and an air compressor to flush the condenser and evaporator if not replacing.
-Chad
Kebabaluba
Norway
-Chad
Thanks for the tip. However i`ll be using a dedicated AC service machine that i`ll borrow. That machine should do most of the job, it even injects oil into the system.
Irish Pride
Irish Inside
MusicCityUSA
I have a Robinair machine at work(Ford Dealership) it will inject oil but it doesn't flush old oil out. If you are unsure of the history you will want to get all the old oil out as it might not be compatible. Not to Mention the Accumulator and liquid line would need to be replaced. The Accumulator will be saturated with the old oil.
-Chad
Kebabaluba
Norway
-Chad
For now that will do as i have other more important things to do on my car, i just need the AC to work for few months before i buy new accumulator and stuff. The machine i plan to borrow is a bit more advanced too, its a Texa Konfort 770. Its a pretty advanced machine with oil injection and vacuum mode.
313tiger
