Also, If you have a decent air compressor 26-30 gal+ you can buy a $15 venturi vacuum pump from Harbor Freight that will run off of it. That works OK to vacuum the system; however, you might be able to rent an electric pump from your parts store loan-a-tool program. Then you can save the $100 evac/recharge labor fee a shop would charge. The electric pumps vacuum better. You need about 31 oz. of 134a, IIRC. That's about $45 worth. Not quite 3 whole cans. A shop will charge roughly $150 for the evac/recharge and freon. That's about what I paid. Seriously though, you want to replace that liquid line while you're in there. You have all that crap removed and out of the way, for $25, it would be crazy not to.
I am cheap. I like to half-ass things and cut corners when I can, but a/c is one of those things you can't really half-ass or it will come back and bite you. It's a pressurized system that must be repaired correctly to fully function as it should. Do it once and do it correctly and save yourself a headache. Just did a/c work on my 95 and need some done on my 89.
If those lines are rusty, you may have issues with the quick-disconnect in removing them. Use PB blast in the connectors if you have problems. The line that connects to the bottom of your accumulator and goes back to the compressor is obsolete. If you booger up that line connection, you'll need to go to a hydraulic hose shop and have them install new rubber and fittings done. I had to do this and it cost me about $55. My hose connection got "out of round" because I had to use vice grips to remove it. You live in the North and I live in the South---and mine was still seized on there due to corrosion. Just keep that issue in mind as well.
Post back or PM me if you have any other issues. I just went through this ordeal myself, so I'm very familiar with it.
