mcrowe3797
I just got the new ac cycling switch for R134a....
So i let the ac cycle for 2-3 minutes. It was low every 3-5 seconds it would cycle. So i added more. Once it was steady at about 40psi it shuts the compressor off and doest come back on. Could it be because i messed with the screw on the switch? What would the stock setting be set at? 90 mtx sho. It cant be the clutch since it cycles on when it was low? What should the PSI be on the lowside while running?
I put the old switch on and it wont come on unless i let it sit for a while?
Does anyone have any suggestions?
