ABS!
KentuckySHOoff
Bardstown,KY,
OK - after a wreck my abs light is staying on, but the abs still works (I think) I can't figure out why the damn light is staying on. I was told on here to pull the fuse out of the power distribution box, well there are 2 of them, which one do i need to pull? I pulled both of them and the light stayed on but i just let it idle when i pulle them do i need to give it some time or what? That light is driving me CRAZY!!! :mad:
When I pulled them I pulled one then the other one then both of them at the same time! HELP!
<small>[ November 18, 2002, 12:03 PM: Message edited by: KentuckySHOoff ]</small>
Looking at the fuse box with the two small fuse at the bottom or closest to you, it is the fuse on your left market Accsy Relay.
Unfortunately if the Gen 2 is like the Gen 3 and you pull the fuse while powered up you will set a hard code that will need to be cleared by the dealer. They will have to burn the code out if the system. It will not go away by disconnecting the battery.
