93silverbulletSH0
Just seeing if this is normal... When turning sharply (quick rights) the ABS kicks in (or at least the pedal shudders pretty bad) about halfway through the turn if I am still on the brakes relatively hard (not hard enough to kick in ABS going straight). I went out and made a couple different panic stops to make sure it was the ABS kicking in. 60-0 pedal to the floor ABS barely kicked in (mostly at lower speed), and pedal barely shuddered. 30-0 more shudder but still not as bad as when turning. 20-0 on the dirt caused pedal to shudder violently, worse than when turning but closer than others. One time I was pulling into my driveway, there was someone behind me so I pulled all the way to the right so they could go by as I slowed and made a right into my driveway. I was still going about 10 mph and using medium braking force when my tires went up the sloped curve into the driveway it did it again. No ABS light has come on, but I have't checked the codes. Does anyone elses car do this? I wast able to dig anything up through the search. Sorry for the long write up, I like to provide as much relavant info as possible. Thanks.
